zoe knight
Posted on - 11/29/2011
I am sharing the same Apple ID with my wife. Now, I’m thinking of providing an apple ID for her. Ever since iCloud started, my wife and I used to download applications from it. I want to know now, does anyone tried using another Apple ID to replace the old one? Is it okay to switch users and is it necessary to sync it with iTunes to occur the desired changes? If it is, will I able to retain all of the files which is should have stored in her phone. Any suggestions?
Switching Between two Apple ID’s
MacRumors provides learned which Apple company is focusing on a method to merge numerous Apple company IDs into just one login. The matter associated with rearrangement multiple The apple company Identification logins has been A minor inconvenience previously, however with the actual earlier creator testing associated with iOS 5 as well as iCloud, customers are finding that to become a main concern.Â
TUAW explained the issue back July, and also the solution during those times was that there had been not a way to unify Apple Identities:Â
A few visitors have been managing two Apple company Identifications on purpose and are right today frustrated concerning the proven undeniable idea that The apple company is reducing logins with regard to automatic acquires. Others have got simply merely discovered that they have 2 IDs.Â
The majority of them have already phoned Apple, simply to tend exactly the identical response without elision: Apple company will not unify Apple ID accounts.Â
MobileMe customers especially are finding that they now have a minimum of a couple of Apple company Identifications, their original a single as well as their particular Mobile Me accounts. Juggling numerous logins while using the Organization’s Automatic Downloads can be a certain chore as you cannot very quickly swap between logins. Apple company tresses disposition to an individual Apple company Identification for 90 years, preventing any kind of rapid moving over between company balances.
Hi Zoe,
You can create another Apple ID for your wife. However, I regret to inform you that there's no way for you to change it. Once you've downloaded a specific apps using your old Apple ID, there's no way to sync it to your new Apple ID. The downloaded apps will retain to your old Apple ID. If you want to download again that specific application using your new Apple ID, just download and install it to your device. Also, you can retain all the Downloaded applications to your old Apple ID as long as you can access it.
Hope these information might help to your question.
Goodluck,
Edwin Malig
