Hi! I have been using Google Chrome from a very long time but due to recent crashes on it I switched to Firefox. But the problem is that I still keep seeing Firefox crash. I get this script error:
A script on this page may be busy, or it may have stopped responding. You can stop the script now, open the script in the debugger, or let the script continue.
Script: DANGEROUS URL REMOVED:192
What is the problem? Is it something to do with my computer? Please Help! Thanks!.
Switching From Chrome to Firefox
Hello Jimmy!
This is cause of one major reason virus, spam, malware, etc. Though you only switch from one browser to another it still possible.
The best way to resolve this is to install any software that will prevent from virus attack or malware attack. Updating the browser will also give you best results. In this process you can also see that your system will be clean. Will gain speed in most processes. Installing a dependable and stable antivirus will resolve this issue also.
There can be differnet resaons for the rashing issue of firefox. You can try following ways to resolve the issue.
1. Start the browser in safe mode without having the add ons
Open the browser –> Go to help –> Disable the addons
2. Reset the browser to default state
Open the Browser –> Go to help –> Troubleshooting Information –> Reset Firefox
3. Disable Hardware acceleration
Open the browser –> Go to Options –> Advanced –> Disable 'Use hardware acceleration when available'
Hope this helps!
