michael.
10 points
Posted on - 07/18/2011
Hi everyone,
I am trying to write a small application that will connect to a sybase database and will run a query. This query should be outputted to a label text later on. By the way, I am using sybase 11.9.2 running on Windows 2000. I have tested the connection via Sybase , but while running the application, I am getting this system error:
System Error
Error Number 2.
Error text = Null object reference.
Window/Menu/Object = w_product-master.
Error Object/Control = w_product-master.
Script = pfc_postopen.
Line in Script = 34.
Has anyone else experienced a strange system error like this ? What could be the possible cause of this problem? I would appreciate it if anybody could help me solve this problem. Thanks to those who will offer solution.
Sybase Database System Error No. 2
System error code 2 means "The system cannot find the file specified." This error code may also display as "ERROR_FILE_NOT_FOUND" or as the value 0x2.
SQLCODE is a numeric code associated with an exception. Negative codes are considered errors; positive codes are warnings.
This guide lists messages in numerical order as if they are all positive numbers. If a SQLCODE has both a negative and a positive value, the first message listed is 'Warning nnn' (the positive SQLCODE), then 'Error nnn' (the negative SQLCODE). The SQLCODE 0 indicates successful completion.
To simplify navigation, messages are grouped by range. To locate information about a specific error, click on the appropriate branch of the navigation tree, then choose the page that contains the error code.
