I have HTC Sense which I wanted to use Sygic Application and each time I try installing this App, I am getting this Error message that the App wants an upgrade, when I try upgrading, the app states that there is no enough memory to install the App, what could be the problem here? I have enough Memory(free 2GB internal, External I have free 8GB), How do I get this app running?
Sygic is GPS navigator software for Android. When you try to download/upgrade the application, it in turn requires huge memory to store map information and primarily on the phone memory. Un-installing the updates for the apps may solve the problem. However, that’s not a long term solution as you will be requiring updating the software from market time to time. I would recommend you to download the application from google play store in your computer. Then connect your phone with the computer and transfer the application in SD Card. Now install the application from Sd Card. However, you still require a lot of free memory (RAM) in order to run this application which is very resource hungry.
I’m not sure if the HTC Sense model has different storage capacities in other countries but the standard HTC Sense Smartphone has only 1 GB internal storage and a very small 768 MB RAM. Here are the complete specifications of the phone. The HTC Sense is a 3G Smartphone operating 2G and 3G network bands using GSM and HSPA technologies.
HTC Sense
It was unveiled to the public on April 2011 and released on May 2011 measuring 126.1 x 65.4 x 11.3 millimeters and weighing 148 grams. It uses mini-SIM card but the phone has been discontinued. It has S-LCD capacitive touchscreen display with 16M colors at 540 x 960 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass with HTC Sense UI 3.0.
It runs on Android 2.3.4 Gingerbread upgradable to Android 4.0 Ice Cream Sandwich powered by Qualcomm MSM8260 Snapdragon S3 chipset, 1.2 GHz Dual-Core Scorpion processor, and Adreno 220 GPU. It supports microSD expandable up to 32 GB. It runs on 768 MB RAM with 1 GB internal storage.
The primary camera supports 8 megapixels with AF and Dual-LED flash featuring geo-tagging, touch focus, and face detection and supports 1080p video recording at 30 fps with stereo sound rec. The secondary camera supports VGA. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 3.0 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0 with MHL TV-out support.
It has built-in accelerometer, gyro, proximity, and compass sensors. The pre-installed web browser supports HTML with Adobe Flash support. It runs on removable Li-Ion 1520 mAh battery with standby time up to 350 hours on 2G and 400 hours on 3G. Talk time is up to 8 hours 20 minutes on 2G and 6 hours 40 minutes on 3G. It is available in Black and Ice White colors.
If when updating the app it says there is not enough memory available, you probably have many apps installed. Try changing to a much bigger 32 GB microSD card.
1....
