Isabellartd
70 points
Posted on - 02/06/2013
While installing Symantec Endpoint Protection client, on windows 7 64 bit machine, i received a warning message seeking for higher privileges for installing the SEP client and I cannot continue with the installation process.
This version of Symantec Antivirus Win64 requires elevated privileges in order to install. Please log in as an administrator, or contact your network administrator for help.
Please help.
Thanks in advance.
Symantec Antivirus Win64 requires elevated privileges to install for Windows 7 machine
It could be that there are multiple users on the computer you are using and you are not the administrator of it. if this is not the situation, do install it this way then
pop the disc in, I'm assuming you are using a disc to install SEP.
normally it will autorun. so, do not install it yet.
go to My Computer. Open the drive icon for your disc or simply goto the setup file for SEP.
right-click on it and then select "run as administrator".
This procedure should take care of that administrative privileges and get your SEP installed.
BUT, if you are not the administrator of the system and not the only user of it. It might require a password.
To install Symantec Endpoint Protection Manager (SEPM) you may follow the following 8 steps:
Insert the installation CD and start the installation.
In the installation panel, click Install Symantec Endpoint Protection Manager.
In the Welcome panel, click Next.
In the License Agreement panel, check I accept the terms in the license agreement, and then click Next.
In the Destination Folder panel, accept or change the installation folder.
Do one of the following:To configure the Symantec Endpoint Protection Manager IIS (Internet Information Service) Web as the only Web server on this computer, check Create a custom Web site, and then click Next.
To let the Symantec Endpoint Protection Manager IIS Web server run with other Web servers on this computer, check Use the default Web site, and then click Next.
In the Ready to Install panel, click Install.
When the installation finishes and the Install Wizard Complete panel appears, click Finish. Wait for the Management Server Configuration Wizard panel to appear, which can take up to 15 additional seconds.
Hi
Regarding on this problem to get more helpful information to fix this issue my recommendation is visit this Techyv post too.
Symantec Antivirus Win64 shows error on startup
