lawtom
Posted on - 09/18/2011
My system is affected with virus. Today I install the registered version of Symantec Antivirus in my system and then update it.
After it I scan all my system drives and remove all virus now I want to create its backup, but Symantec virus says with me that you don’t have sufficient privileges.
Can anyone tell me its solution.
Symantec Backup Exec System Recovery
Error E1AD3212: You do not have sufficient privileges to perform this operation. See help for more information about security settings.
        OK
hadey
This problem is possible cause with the Windows Event Log service. If this service of the operating system is corrupted in some way, the BESR service will not be able to start as it relies on the Event Log service.
Some cases have been known to be related to .NET.
Addition to this, ensure that there is adequate disk space when installing software. Free disk space is necessary.
Here's the solution for this problem.
1st, click Start>Programs>Symantec>Security Configuration Tool>
2nd, click on Add., click on the logged on user account and add it to the Security Configuration Tool.
To Restart the Backup Exec System Recovery Agent Service,Â
1st click Start > Run
2nd type in "services.msc" without the quotes <press enter>
3rd right click  on Symantec Backup Exec System Recovery service and select "Restart"
