Marilyn
Posted on - 10/05/2011
I install much software in my computer but in the previous days I get error message in Symantec Endpoint Protection installer information.
Please anyone tell me what this error means and how to fix it or how to install any software without getting this error message.
Error 1327.Invalid Driver: K:
That is really an error. You tried to install Symantec Endpoint Protection Application and Device Control in a different drive that is supposed to be installed in drive C.
There are applications that allow the installation in other partition and this is common to the usual applications that most computer users use like for example Microsoft Office, games, video editing tools, audio and video converters and all other applications that are not that essential in maintaining the integrity of the operating system.
Symantec Endpoint Protection Application and Device Control is a computer security protection application that is usually required to be installed in the main partition of the operating system which is drive C.
You can fix the problem by changing the installation path to drive C instead of using drive K which is a very far partition if you are using a hard drive that has a very large capacity. You cannot install this application in a network drive if drive K is a network drive.
