Symbol visualization problem with ms office word 2007
I am having trouble visualizing circuit diagrams copied and pasted with ms office word 2007. So far I have noticed it is visible with other pcs but mine one is not showing at all.
I do not know if there is a particular settings of format for that which will allow the circuit symbols visible. Kindly someone help me with this problem.
Johan Weiz
Answered By 0 points N/A #109282
You need not to be worried about this issue. If you want to copy a circuit diagram in MS Office program primarily it will be visible at the same place where you have copied it.
However, you have to drag it to the required position with the mouse pointer. It is also easy to insert auto shape from the Insert Menu and Auto Shape option. You will find different types of auto shape here.
You can select your desired auto shape and edit it as Add Text. Now you can insert required field from anywhere. Their designs also follow the same rules as other formatting of font.
I hope you understand it.
Thanks
