Hello, I am an user of Symphony H50 mobile phone. I bought it one week ago. First three days I used WIFI very smoothly in my device. From the fourth day after Installing a few games and software I have encountered a problem with WIFI connectivity. My phone isn't responding WIFI after long time searching for WIFI networks, when the WIFI network is fully functional.
Symphony H50 mobile suddenly stopped responding WIFI after long time searching
Hey there.
This is probably your WiFi receiver is not working because sometimes android fails to load some required drives if the process is getting to high.
1. First try to restart the mobile.
2. Sometimes this is because of the heat your phone is generating, thus keep the phone to cool down and restarting. Sometimes this is not the phone, but WiFi router issue, then try restarting the router because routers have limited user limit.
3. After all that if it still doesn't work, try a factory reset, this should do the magic, because you may have altered any setting which you don't know.
