Symptoms Of Error Code 80072ee6
Why did I receive error code 80072ee6, and what are the symptoms of this error? How can I resolve this error, and what are the causes of error 80072ee6?
You receive this kind of error when you download any update from the windows server update this usually occurs in windows 7. Symptoms of error 80072ee6 are an automatic shutdown of programs. Problems in installing any update and updating of windows may cause an error.
The central cause of this error is that the URL under group policy settings is invalid. The IP address should be valid and original. To solve this error, you must check the URL which is under Microsoft update services many URL includes https if it is HTTP this may cause an error, so changing the URL according to the original URL might help in resolving this error.
