Sync Blackberry Contacts To Gmail Contacts
How to synchronize blackberry contacts with Gmail contacts? What are the benefits? Can calendar synchronization be done? Can it be done wirelessly?
Synchronizing blackberry contacts to Gmail can be done wirelessly, the benefits are; no need for a PC to sync data and saves a lot of time. Steps sync to contacts is:
Step 1: Choose setup on the Blackberry home screen
Step 2: Next, Choose Email setup and select add
Step 3: Then, Choose Gmail from the list and select next
Step 4: Scroll down to find Synchronization Options and then select it
Step 5: Select the Contacts checkbox
To Sync Calendar
Step 1: Choose the calendar option
Step 2: Click Next
Step 3: Then, verify your Google account and then click OK.
Notifications
