Sync Error on iBank: Error Not Found
IBank synchronization failed with an error:
Sync Error
There wan error during sync. Error is not found.
The error message seems to be confusing as stated, there is an error message while syncing but it could not be found. Is there any way that I can resolve this issue?
Answered By 590495 points N/A #120635
I’ve seen several errors in iBank before related to synchronization and one of them is this error “Sync Error There was an error during sync. Error is not found.” You may encounter this synchronization error when synchronizing your account using different devices such as iPhone, iPad, and others. I’m not sure what really triggers it but it is likely to happen especially if you are behind a private server or you are using a private server as your synchronization point.
But in case you already experienced it or you haven’t bump into it yet during one of your synchronization regimens, this issue with iBank associated to synchronization that somewhat tells you that there is an error encountered during your synchronization attempt but the error is missing since it says that it can’t be found, was already addressed in iBank 5.01.
So, in case you have or you haven’t bumped into it yet, updating to iBank 5.1 will fix the problem. If you are still into iBank 4, now is the time to upgrade to iBank 5. Just download it from the link above and install it. Follow the instructions in “Secure purchase” to upgrade.
