Can I sync iCloud for iPad and iPhone with Outlook Express via iTunes without having errors? How can I sync both phones without having a duplicate? I have spent so much time using iCloud with Outlook Express 2010 on my desktop but it still didn’t work. I tried doing it with Apple Care to no avail. I have read some negative posts about iCloud and Outlook Express so I performed a system restore. Is there any other possible way to start the two programs? What are the steps so that the two will work on my desktop? I’m still hoping that there are some ways to fix these. Thanks in advance for the help.
Sync iCloud for iPad and iPhone with Outlook Express
For sure you can sync icloud for ipad and iphone with outlook express via itunes via itunes without having errors. See below how to do that:
First, you will need to plug your iPad, iPhone or iPod Touch into your computer and then you will open iTunes.
You will then need to select the device on the left under “Devices”.
Then you will click on the “Info” tab at the top.
And then check the “Sync Contacts” option.
Next you will need to choose where you want sync your contacts from, and here we know it is outlook which is on windows.
Once you have done that, you thereafter choose to sync all contacts or sync only selected groups.
And the lastly sync your device.
Regards
Thompson Locker
