Ruth Powel
Posted on - 12/21/2011
I wanted to sync the contacts in my iPhone 4 to my MacBook Pro. I could successfully sync my music files to it but I was unable to do it with my contacts. Please tell me how to do this. I have tried doing so but I could not find any ways to sync it with Mac. I need my address book to be seen from my MacBook. Please help me. Thank you in advance.
Sync iPhone 4 Contacts to MacBook Pro
Hello powel,
This is possible to create your contact list profile on your system. this mean you already sync your music from Phone. so sync program have its nature to perform. you can share only supported file only. it does not exist on your system then it occurs fail
Go your prefer folder or file on your MacBook and create notepad, text or other related file and will do your work.
Before you do it shared some small data to MacBook.
Or, plug your Modem PC suit to the PC and install the phonebook option and share it.
You must solve your problem from it.
Thanks
