Sync lotus notes phone, need help on this one
Hi guys,
I have a laptop installed with lotus notes.
All I want is that my files with lotus notes from my laptop syncing with my android phone.
How do I sync lotus note phone?
Hi guys,
There are many options available for Synching Lotus note with Android phones. One of them is SyncCell Version 3.4.02. With this you may Sync Lotus Notes to your Android phone with one click. You can download its trial version for free and it's one-time cost is $24.99.
               OR
You may download AweSync to synchronize your lotus notes calendar, contacts, tasks and notebooks with Google.
It's easy to use and it's a one time cost is $19.99
               OR
The other option available for free is NotesAndroidSync. It synchronizes the Lotus Notes calendar to the calendar on the Android phone. It works only via Bluetooth.
Laz Zebbena
