Synchro contact Gmail wave 3
I use my Samsung phone both at work and at home but my business contacts are saved in gmail. How can i synchro contact gmail wave 3 without the synchronized contacts being saved to the phone memory but only fetched at that particular instance?
Answered By 0 points N/A #166119
This what you have to do: First, start by pressing the home button that will take you to phone’s main menu.  Then, go to the Email option and select Exchange ActiveSync (for new account).  Now, enter your email address, your username, your password and leave the domain name empty.  Press next and the phone will go to: checking and verifying mode.  It will then ask you for the server url so type in m.google.com and opt for SSL.  Select contact and task sync and the phone will begin to sync your data immediately.  This procedure will not take more than a few minutes. It all depends on how many contacts and tasks you have on your Gmail Contacts and Calendar.<!–
I hope this is useful.
