Hi there,
I try to sync Evernote with my iPhone using my PC and I have this error on my iPhone. I don’t know what this u2 error means and I have no idea on how this can be solved. Please is there someone who might help me to fix this ? Is there a problem with my PC or with my iPhone ?
Thanks !
Synchronization failed.
Unknown Error u2
OK
Synchronization failed. Unknown Error u2
Hello There,
Please ensure you didn't d certain changes in system. Changes even includes installation of new apps.
This is purely apps bug, and known to vendor. They have released a patch, my advice once this is available for your device, you just update it as soon as possible.
Actually,"u2" error comes if you create a note and keep body of the note as blank. The empty note won't synchronize. You can work around this problem by adding some text to the body, or else by reinstalling our app.
