Synchronization process fail due to AdCenter internal error
Hello!
I got an unusual error after trying to synchronize some changes of my account. A message came in that the synchronization process has failed because of adCenter internal error. Do you have any suggestions on how can I complete the synchronization process? What must I do to fix this problem?
Error:
Sync changes-suizong017 Sync failed Errors detected adCenter Internal Error
Answered By 55 points N/A #91990
It must have been a lot easier for me if you would have included a screenshot of the log file. Though I looked in the internet and found out the log found. It says that in previous versions, there is a bug in the language region and network distribution settings.
The first option error is solved in the new update. So I would recommend you to download the latest update from their site and install that one after removing the previous version.
The next error is due to the network settings. Where country is not the United States, set the first option in the network distribution.
You can also get some help from Bing Ads Community Blogs and Forums. They all include some explanation to you problem.
