Hello Experts,
I need your help! My iPhone 3gs won’t let me add things to it and it was synced with iTunes library. I erased all my songs and videos when I tried to do it manually. How can I put in things without losing them?Â
Waiting for solution.
Syncing Apple iTunes to iPhone
Good day Jonathon,
Here are some solution that might help you sync your 3gs to iTunes.
First, connect your 3gs to your pc and launch iTunes then select the iPhone option in the iTunes sidebar. Then select which things you want to have synced and after that click the apply button and wait for it to complete the sync. hope this one help. thank you and god bless.
Hi Jonathon Head, connect your iphone 3gs on your computer. Your computer should have itunes so that you can put music and video to your iphone 3gs. You can add manually or add all of the items that are inside your itunes. After copying music on your iphone, make sure you will not delete the file on your computer so that it will not be automatically deleted when you plug again your iphone to your computer.
Another way of doing the same is to create a custom playlist on your iTunes by going to File menu and select New playlist. Add music to this playlist and then go to your iPhone window and select the music tab then you will see the custom playlist you created and select it. Now you can click sync and your music will not be lost.
