Syncing Gmail contacts with iPhone
I use iPhone 3G and I want to synchronize it with my Google Gmail contact list.
How can I synchronize them?
Can I use iTunes?
Can I use iTunes?
Hi Jesper Torres,
Apple and Google made it really easy to synchronize contacts. To synchronize your Gmail contacts with your iPhone 3G you need iTunes software and an internet connection. Follow given simple steps to synchronize.
For Microsoft Windows XP, Vista, 7:
1. Install latest version of iTunes free.
2. Connect your iPhone to your PC.
3. Select your iPhone in the iTunes.
4. Click “ Info” tab and select Sync Contacts With.
5. Select Google Contacts.
6. Enter your Google mail ID and Password then hit OK.
7. Synchronize your iPhone now by clicking on the Sync tab of iTunes.
8. Now Your Gmail Contacts are synchronized with the iPhone.
For Mac OS X:
4. Click on “Info” tab and select Sync Address Book Contacts.
5. Select Sync Google Address Book Contacts.
6. Click the Configure button.
7. Enter your Google mail ID and Password then hit OK.
8. Synchronize your iPhone now by clicking on the Sync tab of iTunes.
I hope you will find the answer helpful.
Regards.
