Syncing outlook calendar to iPhone calendar
I want to transfer my Outlook work calendar to my iPhone 4S. Can I do this even if iPhone uses a different calendar? Is it simple or do I need to get an experts help? Â I am not a tech savvy person.
Hello Garry Silva
iPhone is one of the most popular smartphones. Using calendars for various typical day purposes is very common. Again outlook calendar is the most popular among pc users. So we all may need to sync between these two techno things. Here's a way:
FIRSTLY
you need iTunes installed in your smartphone. once done,open iTunes software. connect your smartphone using data cables & you can operate your phone through the software
SECONDLY
Once your phone is selected under the "devices" option in the source list,click the "info" button. afterwards click "calendar" & later on click "sync calendars from".then click "outlook".
FINALLY
if you want to sync all the calendars then select "all calendars" or you can manually select the required ones. hold the control button and keep selecting calendars for custom selection. Once you are done click "Apply"
That's it!You're done with synchronizing
