Syncing the photos from Android device to Dropbox
Is it possible to sync the photos from Android device to Dropbox? Is there any document available for using Dropbox as a service which uses a CNAME record that points to a server?Â
Hello Editha,
To sync photos or file to your dropbox, make sure that you have downloaded or installed dropbox application. If you already have that application, you can do the following steps:
You can check out the image below so that you can be enlightened and know more about what I am talking about. I hope that this solution might help you solve your issue. Please let me know. Thanks and good luck.
The possibility to sync photos from Android device to Dropbox is reach, by the use of Dropbox software installed. This app allows you to save and store data from the web server. Amazon has this feature that allows you to store data and upload files using the Dropbox app software.
This online storage web service is one of Amazon's web Services to let there subscriber to store data from the web server.
It has charges ranging from $US 0.15 per gigabyte in a monthly bases, charges for bandwidth use, send and receives.
Once and after the Dropbox app software is installed, you are all ready to make use of this app to the fullest. Sync photos, upload and download files and these are all secured while in process and progress.
It needs index documents to host static websites provided by web hosting provider. This supposed Dropbox app configure CNAME to records to host http://subdomain.example.com.
It display the default page if the URL is invalid, but this CNAME only allows sub-domain to be hosted in this way because some may use ANAME to record S3 server, but it's not documented by the web host, like Amazon.
