Synopsis On Encountering The Issues With The Windows Certificate Authority
Hello, I am facing an issue I can’t access websites after the latest update from the windows due to windows certificate authority. What should I do to overcome this issue?
Hello, here are the ways to overcome the Windows certificate authority issue. Choose which suits you the best.
a. Firstly check your time and date and make sure you adjust accordingly.
b. You can always download the missing certificates from the internet. It’s a simple click on the lock icon, which is next to the name of the website and selects to view certificates.
a. Now, Search for Warn about certificate address mismatch option and turn it off.
b. Many of the times it happens due to the TLS in internet options in the advanced tab in the system. So, find out TLS 1.0, TLS 1.1, and TLS 1.2 and unselect and click save changes.
c. Click on internet options and then security tab and press on the trusted sites and enter about: internet and then press on add. Thanks for writing!
