Syntax Commands For PowerShell Add Computer To Domain And Workgroup
What is the syntax used for PowerShell add computer to domain or any workgroup? How to add a computer to domain or the workgroup using PowerShell?
The PowerShell syntax to add computer to a workgroup is:
Parameter Set: Workgroup
Add-Computer [-WorkgroupName] <Name of WorkGroup> [-ComputerName <Name Of Computer []>] [-Credential <Credentials of PS>] [-Force] [-LocalCredential <Credentials of PS>] [-NewName <String>] [-Confirm] [-Restart] [ <Write Common Parameters>]
Add-Computer [-DomainName] <Name of the domain> -Credential <Credentials of PS> [-ComputerName <Name of PC[]>] [-Force] [-LocalCredential <Credentials of PS>] [-NewName <Input String>] [-Options <Join Options>] [-OUPath <Set Path of OU>] [-Restart] [-Server <Server Name>] [-UnjoinDomainCredential <Credentials of PS> ] [-Unsecure] [-Confirm] [ <Write Common Parameters>]
