How does the Syslog in Windows using the open source work? What is the use of the Windows Syslog server and how can we troubleshoot the Syslog server which is running in the basics of windows?
iansilva
Syslog Servers And Their Uses And How Can They Be Used And How Can We Troubleshoot The Syslog In Windows Using The Open Source And Make Use Of It.
Windows Syslog is generally used to know what’s going on the system, it sends the message and the notifications to the system and then we can get the notification on the screen this type of incoming of the notification on the screen what is happening in the background is handled by the Syslog.
Has the windows Syslog is anOpen source we can use it anywhere and also edit the functionality’s and select what we want to see and for all the incoming and outgoing things we need a notification.
This is generally present in all the windows running system. In case there is no Syslog preinstalled in the windows system then follow these steps to get the notification what is going or running in the background of your system.
The windows Syslog is a software which also runs in the background and keeps track on all the thing which are running in the background and gives the instant notification for the preferences which are made by the user.
Steps to be followed to check on the Windows Syslog and troubleshooting the Syslog:
Step 1: In case you have the Syslog in the windows Install Kiwi Syslog server which can be downloaded from the net.
Step 2: Install the software.
Step 3: You will find an Add button on the top right click on it.
Step 4: select applications for which you want to get notifications.
Step 5: Select which type of message notifications you want to see.
Step 6: click Finish.
