Sysmenu,dll Error Windows 7 Solution Being Blocked
Sysmeny.dll is related to Adware programs. It is an ad that has been added in the browser that you visit which is being blocked by the Antivirus, thinking of it as a threat to your computer and gets removed. Some of the threats names that have been given are ADWARE/Adware.Gen7,Skodna A80,DUA. Optional. Goobzo, Win32/Trojan, Adware 37c, Goobzo(fs).
This error also Arises as a result of entries during software updates. By updating from Win8 to Win8.1. You can stop this error by stopping the Windows from attempting to load a file. You can stop it from loading by, downloading the free program Autoruns by Microsoft. It is Available at Microsoft Technet. You need to find sysmeni.dll at the end with the yellow highlighted image. You can locate the image path from the tab named “Scheduled Task.”When you find the file, delete it. Now you have to find all the yellow highlighted image path that ends with sysmenu.dll. You need to be careful while deleting. It might cause a problem. Now you have to wait for 5 minutes to confirm the problem has been solved.
Notifications
