keaton watt
Posted on - 12/26/2013
I am trying to install a new software on my computer but it always shows an error. No matter what software I tried to install, it always failed. I don't know how to get rid of it. I tried installing the same software on another computer and it works so I am sure that the problem is on my computer. How can I fix it?
The error is:
Warning!
Your system administrator has disabled the option to install any software on this computer per company policy.
System Administrator has Disabled the Option to Install Software
I assumed you have InstallGuard in your computer because this error comes from InstallGuard freeware application blocking program. It can detect and block installation of unauthorized software. This will monitor new software installation on your Desktop, Documents and other locations. So if someone tries to install any software, you will most likely to receive the same error message. To fix this, I will suggest that you check if you have InstallGuard and disable it to get rid of the error.
