The System Cannot Find the File Specified
Aside from the problem that I posted before, It is now producing this new error message. It says that “Sorry, no tables found Could not find any tables that meet your criteria, The selected game, stake or structure is probably not supported by a server-side-scan yet. Do you want to switch to client-side-scanning instead?”. What does it mean by switching to client side scanning? Will I be disconnected?
![](https://www.techyv.com/sites/default/filesx/users/William%20D%20Hampton/image041_0.jpg)
The system cannot find the file specified
OK
