‘The system does not support full screen mode.
Hello
When I attempt to run turbo c++ IDE on most recent version of windows (Vista or Windows7), I get the following error: 'The system does not support full screen mode. Choose close to terminate the application.'
I need a solution of it. Please help me.
Thanks a lot.
Best Answer by Argen Manso
Answered By 15 points N/A #150226
Based on my experience when I was still a student most of us were using windows XP because we think that it is the most appropriate operating system that is compatible with the programming language called C++.
To uninstall the program:
1.       Click start button
2.       Go to control panel
3.       Under the Program button
4.       Click “uninstall a program”
5.       Find C++ software, right click and uninstall.
And download the latest and compatible version of C++ to avoid this problem.
I hope this suggestion will help you a lot.
Answered By 10 points N/A #150227
Try to change the screen resolution form the control panel and make sure that you have a valid program to run. Check the program requirements before running it. Also check for any virus in your computer that can cause this problem.
Smith Thompson
