System Error 14001 Side-by-side Configuration Is Incorrect On My Computer.
I am a computer professional. I am currently using the Windows operating system on my PC. Recently, I have encountered an error 14001 side-by-side configuration is incorrectfor your computer. Please help.
Answered By 0 points N/A #292994
This error is generated by an exception handler. It arises due to incorrect parsing of the XML data. Please also put the trace or the log file along with your question. You can rectify the error from any of the methods given below.
  1. Make sure the syntax of the XML data is correct. Make sure there are no missing opening or closing tags. Make sure all XML tags are identified during the parsing.
  2. Use the sxstrace.exe tool. The tool will give you the exact trace of the error in XML format. You can then check this data for parsing errors. Remember to run the sxstrace.exe application in trace mode.
Answered By 590495 points N/A #308128
According to Microsoft, you may receive “side-by-side configuration” error if your computer is missing the correct Microsoft Visual C++ runtime components for the type of system you are using (32-bit or 64-bit). To fix the problem, download and install the following Microsoft Visual C++ update according to your platform architecture:
