System Error Code 5, Access is denied
40 points
Posted on - 07/17/2013
I receive the following System Error message when I am in progress running programs and saving its data. The error message says that “Access is denied”. Can I fix this problem with your assistance? Guide me with e best resolution.
I would be grateful to you.
Error: Can’t create file ‘C:Program Files (x86)WinSCPWinSCP.ini’. System Error. Code: 5. Access is denied
