Everytime i tried to create a recovery disk it showed me an error message.
It loads 1/3rd of the first disk and then it stops with the error message.
Tell me how can i resolve this problem?
TOSHIBA Recovery Media Creator
An unexpected error occurred.
(Error Code: 040ECA-70-70-00000000)
System fails, can’t create a recovery
Hi Celena,
The problem you encountered is due to Windows system file corruption.The causes of system file corruption are unfinished install, improper deletion of a software application or hardware or by incomplete deletion of files. Some cases, there is a virus or spyware attacking on your computer. To deal with it, these are the ways;
Open your computer and start as an administrator. Go to Start button, go programs selects Accessories, choose Tools and click System Restore. A program will open and chose "Restore my machine to a prior time" then click Next.. Select a restore point from the latest system restore date. Click Mest for confirmation. Finally, restart your computer when you finished restoration.
I hope this will help.
