System File Checker Not Working
I have run sfc /scan now on command prompt to check and ensure if there’s an error with my Windows XP Professional. But when I typed on the command prompt, nothing happens. I opened the Run command then type cmd on it, then type the exact command sfc /scan now. I tried doing it as the administrator but nothing happened. Every time I hit the enter key, the cursor will go down but it is not scanning. I tried to reset the SFC to its default, by typing sfc /scannow REVERT, but it does not change a thing. Sometimes this error appears; The RPC server is unavailable, but sometimes the cursor will just go down to the next line on the command prompt. How can I fix this? I want to ensure that my system is running correctly. And what does RPC server is unavailable means?
Windows File protection could not initiate a scan of protected system files.
Windows resource protection could not start the repair service.
You must be an administrator running a console session in order to use the sfc utility.
Here are my computer’s specifications:
Acer Aspire M1830
Processor: Intel Pentium Dual Core 3.0 GHz
RAM: 2GB DDR2
Display: Intel Graphics Media Accelerator
Hard Disk Drive: 320 GB
Operating System: Windows XP Professional
Anti Virus: ESET Smart Security
Default Browser: Mozilla Firefox
I never tried running SFC before.Â
My friend just advice me to run this to correct all the errors and missing drivers on my computer.
Please send me detailed instructions.
Thank you.
