System going off by self after Norton Antivirus installation
I installed Norton Antivirus in Dell latitude D430 laptop, after the installation system running very slow and some time going off by self. How I can solve my problem?
Hello dear,
This is due to the Norton antivirus because this is very heavy almost this is installed on the server in the large organization.
Therefore when you install it on your laptop therefore becomes slow because it has the RAM low comparing with the large organization server also this whole pigs Internet to the RAM to your entire system.
It also gives you the successes (impacts) false to say something are a virus when its not the thing Graciosa consists when suppresses it and directs another exploration of the virus seems to find 2 or more then seems that Norton depends on a lot of the whole show and won't sympathetic Yes beautiful appearance and easy but its eats the RAM as the guy beset by Christmas.
Lose it and become a very RAM and computer friendly anti-virus like AVG or Avast.
Norton Antivirus is heavy software. It requires at least 256 mb ram. Your systems configurations must be not up to run heavy software. Hence you are facing issue. Install light versions of Norton.
That’s normal when installing a security program like antivirus or internet security. This can happen if you didn’t check the system requirements of the application before installing it or your system falls on the minimum specifications of the program. One way of fixing this is to upgrade your machine.
Try adding more RAM to your system and or upgrade the CPU by replacing the processor with a much faster one. If this is not an option since it means money, another way is to replace the security program you installed with another application that has a much lower system requirements. Since you installed Norton antivirus, try replacing it with a different antivirus.
Try one of the following security software:
Notifications
