System Out of Memory Exception Error
During exporting of files after the data capture of client records, we encountered an error at the middle of file exporting. What does it mean when the system is out of memory?
Is this related to insufficient memory of the laptop? Below is the screenshot of the error we encountered.
Unknown error
Exception of type 'System.OutOfMemoryException' was thrown.
Answered By 0 points N/A #161780
The System out of memory exception is thrown when the available free space for the program to run is not available in the main memory. As such the minimum requirements for the software if met can fulfill your requirement. But if the requirement is large enough otherwise, then the RAM size has to be increased or that you need to reduce the amount of RAM needed for the other application. Either you close some applications, or close some part of it to reduce the usage of memory. Restart the computer and then close some applications. You may try increasing the virtual memory.
