Dear experts
I want to use Merge application from araxis on my windows xp machine. Merge helps in comparing texts from OpenDocument, Microsoft Office, PDF AND RTF files. Not only that it also compares the source code files written in xml and html format.
I want to know the minimum system requirement for merge application on windows xp.
Also tell me if araxis merge 2008 is a freeware or shareware application.
Thanks in advance.
System requirement for araxis merge 2008 in Windows XP?
You can use merge application from Araxis on you system, Minimum requirement is Windows XP professional with SP3 if you don't have SP3 you just need to upgrade you system to SP3 because you already have windows XP, RAM 512 , Processor 1GHZ and Free spare more than 100 MB ,you can download it from given below link
https://www.araxis.com/merge/documentation-windows/release-notes
Hope this will solve your problem
Thanks
McNabb
As an alternative solution, I can suggest you code compare tool. It’s also a pretty good soft for merging
