System Requirements For The Paragon Hard Disk Manager Free And Supported OS
Hello, notify the system requirements for the Paragon Hard Disk Manager free and its supported OS as well. Thanks for solving and reply ASAP
Hey, the supported OS for the paragon hard disk manager free is in various windows platforms such as windows Xp ,8 , 10 and also in windows 8.1 and many others as well. The same is used to store the supported files such as Fat 32 respectively and also supports the HDD, DVD and may other devices as well. Below shows its specifications:
• It has 512 MB of RAM in it.
• The HDD space must be minimum 1GB respectively.
• The process is 300 MHz of more than that.
• Also has the Intel Pentium processor or whichever is compatible too it.
• Supports the IE 5.0 and more.
If you want to install Paragon Hard Disk Manager, you need to make sure your computer meets the requirements. The latest version, Paragon Hard Disk Manager 15 Suite, supports Windows XP (Home or Professional edition), Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 300 MHz or faster Intel Pentium or equivalent processor, 256 MB RAM, and 1 GB free hard drive space.
It supports Microsoft Internet Explorer 5 or higher. Paragon Hard Disk Manager supports the following file systems: ReFS, NTFS (version 1.2, 3.0, and 3.1), FAT16, FAT32, Ext2, Ext3, Ext4, Linux Swap, and Apple HFS+. The following partitioning methods are supported: GUID-Partitioning Tables or GPT, Master Boot Record or MBR, and Windows Storage Spaces. It can also support hard drives greater than 2 TB.
The Windows 10 support is one of the latest features added to the program. They also include support for AES or Advanced Encryption Standard encryption method. If you are thinking of buying it, go to Paragon Hard Disk Manager to know more about the product. It costs $49.95. You can also try the product for free for 30 days by downloading their demo version.
