System Requirements for a single network
If we have a single network with 100 Mbit for data & VoIP, what are the system requirements needed before the installation?
For LAN of two computers, you may need a network adapter called router. It is possible that this router is a wired network router or a wireless network router.
For wired router you want network cable that connects to router and computer network adapter. And for two computers you want two network cables. You want that you connect correctly. Make power on router.
Computer necessary have a wired network adapter and nothing required anything else.
For wireless router you want that adapter of your computer must be a wireless adapter.
You may only need to setup windows network adapter.
