System Security Guard Portable 2.1
The protection based software System Security Guard Portable 2.1 is very reliable. Is there any problem with running this soft with MSE?
There is no problem or difficulty with running System Security Guard with Microsoft Security Essentials. Although most of the time installing and running two virus guards on a same computer can not be done, System Security Guard is not typical antivirus software like Microsoft Security Essentials. Â System Security Guard is a secondary security option for your computer which uses minimum system resources and uses cloud & community file database so you need internet connection is required for accurate usage.
System Security Guard is compatible with most of the customarily used antivirus software or virus guards. So it can be used with Microsoft Security Essentials without any problems or issues. But Microsoft Security Essentials itself is a powerful antivirus software capable of protecting your PC from any security threat.
System Security Guard 2.1 is an outdated version and the latest is version 3.1.0.410. System Security Guard is a useful and dependable program that is designed to scan the computer for any vulnerability. This is important to make sure that your system is safe and secure. If your computer is already installed with an antivirus, there will be no problem using it.
It will not interfere with the processes and activities of the antivirus or whatsoever. It will not also eat too much space from your hard drive. The installer is only less than 2 MB. System Security Guard connects to an online database for it to detect the latest threats.
This application is totally free. It supports Windows 2003, Windows XP, and both 32-bit and 64-bit versions of Windows Vista and Windows 7. This version also contains a brand new user interface, new section added in the settings, enhanced the security scanner and security notifications, and updated the languages supported.
To download, visit System Security Guard 3.1.0.410. See screenshot below.
