System shows Critical and non-critical errors
I was using my system and suddenly some different kinds of error appeared like obscure error, critical and non-critical error. How to solve these following errors? Tell me the cause of these errors.
Bundle of thanks.
Obscure error
Critical error
Answered By 50 points N/A #177066
Hi Swan,
Have you recently installed any third party programs or modified PC settings as the error you've explained above has clear sign of being infected due to installing malware programs. Simply try restoring your system to any previous successfully running date and see if it could make your PC error free.
Alternatively download and install the latest version of Antimalware from Malwarebytes.org and perform a full system scan.
Clean any malware found by the program as well as generate and attach log files in your next reply.
Hope this helps!!
