razib100
Posted on - 08/11/2011
I am mostly into games on my newly purchased Windows Vista Ultimate machine. I found a strange error message popping up when I trying to play a particular game which I downloaded from web. I downloaded the game successfully and applied all the available updates for the game. Now when I'm trying to click on play to start my game, it gives me an error message
john1
System shows Error dll file missing
Dear Razib
Its a common problem mostly arise in windows XP and in Windows vista you never mentioned which file is missing whenever your Vista or XP windows shows an error it also shows the name of the missing file also its very easy to restore the file to its original location you just need to go to Google and type the missing DLL file name and download it to your computer and the copy the file and paste it to the following PATH first double click on your my computer and then double click on C: drive there you found windows folder open windows folder and then double click on System32 folder after opening this folder paste the Missing DLL file in this folder and then go back to your game application it will definitely work.
Hi Good Day,
These problem due to some lessen of file program,file missing and compatibility of the program. To resolve this kind of issue, you must download first the CCleaner to fix the registry of the system program. Please visit this link: http://www.dlldll.com/d3drm.dll_download.html then when you are in there please read carefully the instruction that they given and download the list of file to fix the dll problem..
Thank you, hope its help.
