Here are my machine details.
T60p ThinkPad, model 2623DDU and operating system is Windows 7.
System Update 4.03, the latest version has been installed on my system.
Anyway, I get an error shown in the screenshot as I try to start the application.
Application has generated an exception that could not be handled.
Process id=0x9fc (2556), Thread id=0x1a04 (6660).
Click OK to terminate the application. Click CANCEL to debug the application.
I completed the setup with ignoring the similar error.
Please give me your suggestions to fix this error.
System Update does not start—what to do?
The error seems to be related with UNCServer.exe process.
It is located in Program files and it is a potential security risk which can be altered cruelly by virus.
In that case UNCServer.exe should be disabled or removed if it was molested and brought you UNCServer.exe error.
UNCServer.exe error can be caused by one of the below possibilities:
Damaged or wrong version of the UNCServer.exe
Crashes of browser
A file from Control panel is damaged
Java machine damaged
System hangs
Corruption of dll files
Incorrectness in printer driver installation
A file corrupted from system 32
Loading failure of exe processes
RAM timing, wait states or other Bios settings
