System.ArgumentNullException occurred. Kindly help. ?
 I am having an ajax toolkit calendar extender with the code below:
<asp:TextBox ID="txtStartDate" runat="server" CssClass="textbox" ToolTip="Enter the Start Date"></asp:TextBox>
<asp:Image ImageUrl="/images/cal.gif" runat="server" ID="imgStartDate" ToolTip="Please Pick/Enter a StartDate" />
<ajaxToolkit:CalendarExtender TargetControlID="txtStartDate" PopupButtonID="imgStartDate"
runat="server" ID="CalendarExtender1" PopupPosition="Right" Format="dd/MM/yyyy">
</ajaxToolkit:CalendarExtender>
<asp:RequiredFieldValidator ID="RequiredFieldValidator1" runat="server" ValidationGroup="Submit"
Text="*Start Date is required" ControlToValidate="txtStartDate" Display="Static">
</asp:RequiredFieldValidator>
<asp:RegularExpressionValidator ID="RegularExpressionValidator1" runat="server" ControlToValidate="txtStartDate"
ValidationExpression="(0[1-9]|[12][0-9]|3[01])[- /.](0[1-9]|1[012])[- /.](19|20)dd"
ErrorMessage="* Your entry is not a valid Start Date(dd/mm/yyyy)." Display="dynamic"
ValidationGroup="Submit">
</asp:RegularExpressionValidator>
<ajaxToolkit:TextBoxWatermarkExtender ID="TextBoxWatermarkExtender1" runat="server"
TargetControlID="txtStartDate" WatermarkCssClass="watermarked" WatermarkText="Enter the Start Date(dd/mm/yyyy)">
</ajaxToolkit:TextBoxWatermarkExtender>
When I load the page, it displays the following error:
Error: Sys.ArgumentNullException: Value cannot be null
Parameter name: element
