Systems Requirements For Outlook 2013 Business Contact Manager In Steps Too
Hello, notify the system requirements for outlook 2013 business contact manager and steps to install the same. Thanks for solving too.
Hey, the systems requirements for outlook 2013 business contact manager should have the processor as 500 MHz or more. The Ram should be more than or equal to 256 MB, the HDD space should be at least 2.5 GB respectively. The display will be in 1024 x 768 or more than that also. Below shows the steps to install:
• First go to control panel > programs > programs and features> business contact manager
• Next just right click to and select the change/ uninstall
• Later follow the instruction
• Wait for the process to get over and it’s done successfully.
If you are looking to buy Microsoft Office Outlook 2013 and want to know its system specifications, here are some details about the application. Microsoft Office Outlook 2013 is part of the Microsoft Office 2013 suite and can also be purchased as a separate independent Office application. Microsoft Office 2013 supports Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit.
The 32-bit version of Office 2013 can be installed on both 32-bit and 64-bit Microsoft Windows but the 64-bit edition of Office 2013 is designed only for 64-bit Microsoft Windows. Microsoft Office 2013 requires 1 GHz or faster processor with SSE2 support, 1 GB RAM for 32-bit and 2 GB RAM for 64-bit, 3 GB hard drive space, 1024 x 576 or higher screen resolution, Microsoft DirectX 10-compatible video card, and Microsoft .NET Framework 3.5 or higher.
Microsoft Internet Explorer 8, 9, 10, and 11; Mozilla Firefox 10.x or higher; Apple Safari 5; and Google Chrome 17.x are the only supported web browsers. For Microsoft Exchange integration, Microsoft Office Outlook 2013 supports Microsoft Exchange 2007, Microsoft Exchange 2010, and Microsoft Exchange Server 2013. Microsoft Exchange 2003 is not supported.
For possible Microsoft Lync integration, Office Outlook 2013 supports Microsoft Lync 2010, Microsoft Lync 2013, and Office Communicator 2007 R2. If you want to use the inking features of Office Outlook 2013, you should be using either Windows 7 or Windows 8.
Notifications
