T2S mobile error opening the program after installation
Hello there,
When I run T2S Mobile this application error appears. I have installed the latest version of the driver lately and I expected that everything will work just fine. Anyone knows what could be the problem ? What I did wrong ?
Thank you !
Application Error
Exception EOLeSysError in module T25_Mobile_V4.exe at 000AF529.
Class not registered.
Answered By 590495 points N/A #180461
If you receive this error when running T2S Mobile then you probably don’t have Adobe Flash Player installed on your computer. If you already have it then you probably haven’t updated it yet and you are still using the old version. Download and update to Adobe Flash Player 15.0.0.152. This is the official download page for Adobe Flash Player and the version on the page may change if you’ll visit the page in the future.
Adobe Flash Player 15 [15.0.0.152] supports Windows XP x86 only, Windows Vista x86 only, Windows 7, and Windows 8 both x86 and x64 as well as Windows Server 2008 x86 only and Windows Server 2012 x64 only. This page normally downloads a web stub or a web installer. If you want the offline or standalone installer, click Adobe Flash Player 15.
This directly downloads the complete installer from the Macromedia website. Once updated try running T2S Mobile again and see if it works.
