Finlay
50 points
Posted on - 12/12/2013
Hi there,
We were given these Galaxy Tab tablets at work and every time I try sending a message to non colleagues, a pop up message appears warning that this Tablet is for use only to contact employers and fellow employees, this is disgusting since I may be in trouble and need urgent help, How can I disable this? and can the IT guys view my photos and browser history on the Tablet?
Tablet infiltration possibility, any help?
Hi !
Once you got your Galaxy Tab tablet from your work it has been designed to intern use only. They have installed some software on your tablet that block the access to people which are not in a work colleagues list, and that's why you can't send messages to "strangers". You can't disable this because you don't have administrator access and everything you access on that tablet is recorded on an archive so that can verify you how much you work and how much time you spend online. Is like an info lab at school where all PCs are connected in LAN with limited rights.
