My tablet touch screen pc is was working perfectly lately. Now I cannot access it.
I do not whether it is a touch screen problem or something else.
It does not seem to take the access words.
Please kindly someone tell me what to do in order to solve this problem quickly.
Alonzo Smith
Tablet pc problem – accessibility problem with startup
Hi there ,
It seems you need help regarding your Tablet PC touch screen but unfortunately you haven't specified anything to about the issue ?
Whether its not responding to the touches ?
Whether its not booting at all ?
Or loading and then restarting ?
Or any other problems ?
Without proper details regarding the problem we cant help you specifically .
Generally , Re-Installing the OS in the tablet PC will do the trick.
Just go to the manufacturer website and download then manual and the OS and then read and follow the steps in the manual to re-Install it.
If it didn't helped means re-Post the problem here and make sure you describe what actually the problem is and most importantly please tell which Tablet PC you are using and tuning on which OS.
Good luck.
