Is TagScanner 5.1.667 multifunction scanner? Explain me
Can TagScanner 5.1.667 import information and album art from online databases such as Amazon? Is there any facility to tag fields formatting and rearrangement? Please describe about supported file formats and tags. Is it supported Unicode and Multilanguage interface? In which file formats, can I export? Which operating systems are required? Thank you
Answered By 0 points N/A #171955
Hello Ruth!
TagScanner – free or open source and a multifunction software for arranging and working your music collection. It can edit tags mostly of all formats, retitle the files, and achieve any change of text from tags and filenames. You can get album information through operational databanks like Amazon.com. You can transfer information to HTML, XML CSV or any user-defined format. It also supports multi-language interface and Unicode.
Files Supported – MP3, OGG, Musepack, Monkey's Audio, FLAC, AAC, OptimFROG, SPEEX, WavePack, TrueAudio, WMA, MP4
Systems requirement – Windows 7 (32 and 64 bit, Windows 8, Windows Vista (64-Bit) and Windows Xp.
