Tail Windows 2008 util work within same platform?
I use windows ultimate 8. I want to activate Windows 2008 util in the windows ultimate. How this should be run?
Hi Paul,
In order to run windows 2008 utilities in windows ultimate 8 all you need to do is to configure the compatibility of the utility.
Right click on the utility and then you will see the properties, please click on the properties option.
Once you have clicked on the properties option, a small window will open and it allows you to choose from many different options. You will find a tab at the top which says compatibility. Please select the compatibility tab.
Now under this tab, you can see an option that says run the program in compatibility mode, please check this box, and then choose the OS that you want, in this case I would recommend you select the appropriate one for your program.
Once this is done then click on the application and then click on Ok and you are good going, now the utility of windows 2008 will be compatible with windows 8.
Hope this has come in handy.
Bell Keny.
Notifications
