Taking pictures with your iPhone underwater.
Nobody wants to make a big mistake and dive under water with their iPhone. Exactly how long can the TAT7 iPhone Scuba Case stay under water without getting any water leak?
Hi, I have read your query and concern. Actually, there’s nothing to worry as to how long exactly the TAT-7 iPhone scuba case could stay underwater without causing any water leaks to your iPhone provided that you have followed safety precautions. The manufacturers extremely guarantee total protection of the case to your precious gadget, as long as you do not go anywhere further than 30 meters/100 feet in depth. The case is made-up of robust material of high density polycarbonate and stainless steel which presumably sealed against water leaking in and can withstand even the harshest elements like snow, dirt, and sands. You can also see double gaskets that keep the water out once the phone has been put in the case. At its back, you will see three buttons that allow you to operate the iPhone’s camera applications while underwater. However, given the design, you must remember,  once you are underwater there’s no chance to interact with your iPhone like to use the iPhone's keyboard, or even swipe to unlock the lock screen, therefore you need to set it on camera mode before getting it wet and ensure you turn off the automatic lock timers before you submerge. If you still mind about protection issues, manufacturers of the cases suggest regular application of silicone grease to make sure the phone properly seals out water and functions properly.Â
